Hi All
This is way OT again (!) from me but I have three of the following servers for sale priced at ฃ1000.00 each:
Cisco MCS 7825-H2
Intel dual-core, Pentium D, 2.8-GHz processor with an 800-MHz front side bus (FSB) and 4 MB of Layer 2 cache
2 GB of installed PC2-4200 memory, error correction code (ECC), Double Data Rate 2 (DDR2), synchronous dynamic RAM (SDRAM) standard; 8 GB maximum
Two integrated 10/100/1000BASE-T Gigabit Ethernet network interface card (NIC) ports
Two 80-GB serial-advanced-technology-attachment (SATA) hard disk drives configured in Redundant Array of Independent Disks (RAID) level 1
No floppy diskette drive installed
Quick-deployment third-party rail kit
450W autoranging, Power Factor Correction (PFC) power supply
1RU (1.75 in./4.5 cm high) form factor
Integrated Lights Out (ILO) remote management
Supported Applications
The Cisco MCS 7825-H2 supports the following Cisco applications:
Cisco Unified CallManager-up to 1000 IP phones per server and 4000 IP phones per cluster
Cisco Emergency Responder-up to 12,000 IP phones
Cisco Unified Presence Server
Cisco Unified Intelligent Contact Management Enterprise
Cisco Unified Intelligent Contact Management Hosted
Cisco Unified Contact Center Enterprise
Cisco Unified Contact Center Hosted
Cisco Unified Contact Center Express
Cisco Unified IP Interactive Voice Response (IP IVR)
Cisco IP Interoperability and Collaboration System (IPICS) Software
Cisco Unified MeetingPlaceฎ Express
Cisco Unified IP Queue Manager
Cisco Unityฎ Unified Messaging
Cisco Digital Media System
These servers are professional quality voice/media servers. They are currently running Cisco Call Manager v4.2 (x2) and Cisco Unity Connection v1.2
(x1) and the licences to these applications will be included at no extra cost. They have been removed from a production environment where they
supported several hundred phone users on multiple sites. Ideal for redeployment at a school or business that wants a low cost professional telephony
solution for up to 1000 users. Just add phones and a gateway.
I know it's a long shot here but if any LCB'ers are interested I can offer a full service around these servers. From install through to
ongoing support.
cisco will give you more than that on buy back wont they?
