Registered 1st August 2005. MOT till 2nd August 2010.
Currently on SORN for winter. One owner. Summer use only. 6700 Miles since built.
1800cc XR3(i) Zetec engine running on 4 Fireblade Carbs with Stainless Steel Manifold,
ITG Filter and new Facet Fuel Pump.
130 BHP XR3 Camshafts. Lightweight Flywheel. Megajolt fully programmable ignition.
4 into 1 Big Bore Exhaust to Westfield Silencer. 5 speed Type 9 Gearbox.
Oil Cooler. New head gasket, cam belt and valve stem seals just fitted. Electric Fan. Oil Catchment Tank.
GAZ Shocks all round adjustable for load and rebound. Polybushed.
8 spoke steel 13 inch wheels with Yokohama A519s
Solid discs front with Mintex 1144 pads. Stainless steel braided hoses. New drums rear. Recent Master Cylinder.
Blue fibreglass body. Windscreen with side wind deflectors. Braced Roll Bar with High Level Brake Light.
Carbon Fibre Boot, Dash, Cill Protectors and Rear Arch Stone Guards.
Carbon Fibre on Transmission Tunnel and Bonnet.
EBC Instruments - Revs, Volts, Temp, Oil Pressure and Speed.
Cobra high back seats on runners with 4 Point Harnesses.
Fire Extinguisher. Air Horns.
Price £5400.
Contact bill@brooksb.freeserve.co.uk or U2U for pictures and information.
[img]
[/img]
This is a fantastic car......I can personally vouch for the build quality and the fact its held together with aero fasteners...
Good luck with your sale. Suggest a trip to Stoneleigh if it hasnt sold by then.
Whats next
