Hello,
I have 2 sets of brand new Team Dynamics 1.2 Pro race gloss black 7*15 pcd 4*108 with budget performance tyres Duran 195/50/15. ET35 standard fitment
for a Sierra. Also fitting kit, centre caps, wheel nuts to suit. £360 per set
7.5" 2WD 3.62 believed to be from a low mileage Sierra Cosworth, it has the 108mm lobros, I have taken off the the rear mount on the cover so
this will suit a kit car but not the standard sierra install unless you can find another rear cover.
There is no slop in the diff and when I took of the rear cover the oil was a crystal clear redish colour with no bits in the oil
£150
GSXR750 Throttle Bodies these are the ones that can taken apart and spaced very low mileage, very clean
£100
Also in tank fuel pump to suit above
£40
Clarke CHV12 12-Ton Hydraulic Pipe Bender
http://www.machinemart.co.uk/shop/product/details/chv12-12-ton-hydraulic-pipe-bender
Just to be clear this is a PIPE bender because it is supplied with PIPE bending formers, not suitable for thin stuff £70
Pair of Sierra rear wishbones, ABS fitment type, blasted and powdercoated black, some slight marks excellent condition
£40
I'm based in Hampshire, Chandlers Ford, SO53 2FF
[Edited on 11/5/10 by Minicooper]
you have u2u ref diff
How much for the pipe bender + postage?
[Edited on 11/5/10 by coozer]
The bender with formers and a bit of packaging weighs in at about 50kgs so it's a very heavy piece of kit. Through parcelforce it would be loads
don't know about other carriers, if anyone has any suggestions let me know and I will price it up
Replied
u2u re. diff if it doesn't get sold
7.5" Sierra Diff now sold, thanks Alex
