Before I put this on ebay, I'm offering it to you guys first.
Bear in mind it has cost me £850 to import from Arnott Industries in Florida, so I want £300.
Whoever buys it will need to source some replacement plastic air line tubing, but I still have what I stripped out plus all the required unions.
It comes with a dual needle guage, a switch for each circuit front and rear, air compressor.
Shocks are Bilstein and have done just over 1000 dry miles.
Spring Data:
Load Range 135-790LB per shock
Effective Pressure Min 10psi Max 100psi
Usable stroke 4"
Max in 2"
Max out 2"
Minimum extension 11"
Maximum extension 15"
Design height range 13.5"
Mounts require 16mm bolts and shock mounts are 40mm wide.
Prefer pick up so I can explain how everything goes together!
Ohhh what happened?
I though that you would be running your car with these.
I'm switching to coilovers with hydraulic lifters instead.
[Edited on 6/6/2010 by nitram38]
Just listed on ebay
Ohhh right.
I remember your post about hydraulic suspension and i though that these were the ones you got.
Didn't even think that this was the original setup. Need to look at your car pictures better.
Good luck with the sale
dibs,
u2u on its way
