After this weekend going to Newark I will be removing the Megasquirt I installed over the winter.
I bought this off Phil at extraefi so comes fully assembled and con-coated, complete with wiring loom and the EDIS. It is the TPS version.
It is less than a year old and hardly done any miles. It is set up atm for my ST170 with VVT output. I will label up all the wires as I disassemble
and have the cd and lead that came with it.
£300
[Edited on 15/6/10 by coozer]
so what ECU will you be running Steve ?
Also you might want to let people know which megasquirt it is?
Ms1, Ms2 v3 etc etc.
I'm moving over to an Omex.
I'll check the version out when I get home tonight... Its an MS2 but not sure what the board is.
So tempted, but spent a fortune on the Bike and Car in the last couple of months....... resist!!!!!!!!!!!!
Almost certainly a ms2 v3 then.
Steve, i'll be interested to see what your ST makes on the Omex, i'm just wrapping up a swap to a ST with an Omex 500.
ATB Dan.
May be interested, will you be at Newark to have a chat?
Yes, I'll be at Newark Sat & Sunday
