Following a change of wheels I have these 25mm spacers for sale. They are the hubcentric type - allowing your wheel to be accurately located on the
hub, so you won't get any wobbles. They also bolt to the hub using your existing wheel studs, and you then bolt your wheel to the spacer - no
need for extended studs so you can fit them in a few minutes.
They have a 4 x 108mm stud pattern and a centre bore size of 63mm - great for most Ford hubs. I will include a set of new wheelnuts in the deal.
They are in excellent condition with very little surface rust, having done about 5K miles from new. They originally cost over £100 but I am looking
for £45 plus postage.
[Edited on 18-6-10 by RazMan]
SOLD
