ZZR1100 Engine package
m8kwr - 17/9/10 at 08:16 AM
Its from a 1990 year Bike, apparently had 20,000 miles on the clock.
Its a complete engine/ gearbox with
Wiring loom with Switch Gear
Clocks
Carbs
Airbox
Radiator and Expansion Tank
Oil Cooler and pipework
Standard exhaust
Race exhaust
Ignition system
Chain.
New Sprocket
Haynes Manual.
Copy of original registration certificate with engine no, etc on it.
Also have a GPZ900 sump and oil pickup pipe to help raise the sump so the engine can be fitted lower in a vehicle.
As far as I an tell I believe this has had the carb tops changed to remove the power restriction that it originaly had when first sold in the UK.
Its pretty much a complete package and the only other thing you should need is a sprocket adaptor, depending on what your using the engine for, i.e. Locost, Middy, etc.
Looking for about £350, but open to offers. I live 4 miles from the Stafford car show this weekend so if you wanted to come a see it etc. Obviously pickup only please
mattyc - 17/9/10 at 09:46 AM
u2u
