Nearly all parts are new (except g/box, diff and steering column). I have the sierra donor V5 inc cut out chassis plate.
MK Indy deluxe kit consisting of:
MK Indy chassis (standard black powder coated)
floor, sides and scuttle fitted (all bodywork included - black gel coat)
Bonnet inc bulge/vent
All suspension fitted
Brand new 2 litre zetec fitted to type 9 gearbox
Shortened prop
Diff fitted with reconditioned drive shafts
Wilwood 4 pots and discs on front
rear disc conversion using VAG calipers and cossie solid discs
ali fuel tank and sender
Copper fuel and brake lines fitted inc adj bias valve
New 16" OZ wheels and pirelli tyres
New sierra uprights at front
new quick rack
Swirl pot, LP and HP fuel pumps
Not fitted but also will be included
new starter motor
Used but as new Griffin power systems inlet plenum/manifold
2 injector rails inc injectors (one new; one used)
Spare 16" OZ alloy but no tyre (just in case of kerb damage to one of the others)
Low and high pressure fuel pipes
There's probably even more but can't think at the moment
£3500 ovno
I'm based on the edge of Congleton, Cheshire. Viewing welcome, pics below but the car is quite dusty after being sat for the last year!
Divorce forces sale.
James
u2u
I'd have that from you if only I had the cash to hand!
your rear brakes go into your roll cage????
thats unusual lol
dave
I'm interested in the sierra donor V5 inc cut out chassis plate if the new owner doesn't want age related registration.
How old is the Sierra donor ?
alawrence - you have email!
Jossey - special mod
or just keeping the hoses out of the way!
Breaker - if the new owner doesn't want the age related plate I'm sure we can do something. It's a K-reg
Thanks JEPY
it is exactly what it says on the tin
