Random selection of car stuff!
All for collection from Milton Keynes J14 of M1 or can post some of it.
Mini Steering Wheel, 14", with indicator cancelling tab on rear. Bit dusty and some surface rust to the splines but otherwise good.
Think from a 96ish Sprite.
£10 collected, probably £17 posted.
Rover P6 Battery Cover - New Old Stock.
£7 collected or say £11 posted?
Set of 4 Ford steels think Mk2 Escort, 13" steels in Ford 4x108 PCD. They measure about 6" across but hard to measure with tyres on
so could be 5.5". Back space (mounting face to edge of rim is approx 11cm).
All with tyres 165/R13. Two look goodish, two are knackered. Also come with three centre and three beauty rims.
£30 collected
Triumph Dolomite Front Drivers side door glass. No photo but you can imagine what a piece of glass with a metal channel looks like! Call it £5
collected.
Rover P6 5 Stud Steels - Set of 4.
Set of 4 steel wheels for a Rover P6. With tyres that to be honest are only useful for keeping your winter car off the ground.
Come with two hub caps as well. £30 collected.
Porsche 924 3 armrests. £3 each
Porsche 924 Panel section that holds the sunvisors up and includes interior light - £5
Pair of the lower door aperture seals, OK condition, free.
Porsche 924 Centre console with carpet sides - £5, may well be made to fit other stuff
Porsche 924 pair of rear side windows, with OKish rubbers, one with chrome trim. £5 each.
Porsche 924 Carpet
TWO Big bags of carpet, boot sides, also centre console sides, inside sections. Stick a few quid in a charity collector on your way over and
they're free. Black.
Halfords Oil Filter HOF202 - Think Rover V8 and others
£3 collected, £5 posted.
Selection of Mercedes Headlights and tailights
Ask what you need, think mostly 190E and the W124 saloon.
Mercedes Carbon Fibre Gear Knob
Screws onto shaft. Lost the bit that screws on the bottom. Think real carbon fibre, could be wrong.
£5 collected, £10 posted.
One bike, a Mixte frame that I got as far as cutting the rear bar off to lower the saddle and then lost interest!
£15 collected.
Fold up bike, alloy rims. I ran the rear brake through the frame to look good but works rubbish if I'm honest! Otherwise good, odd scrape and
scratch.
How much is the dutton?
