Had a tidy up this evening, and decided I need to convert some bits into cash!
Record 1-ton engineers vice. Brand new and unused (ignore the generous helping of garage dust!), has 4 inch jaws and opens to ~4 inches.
£25
vice
Rollbar from my Tiger Super Six. It will need repainting, and it was angle grinded from the chassis to remove it, which means that the square feet
don't have enough meat to be drilled and bolted to a chassis now, so it'll need to be welded on to your car, or have new feet welded on. On
the plus side it weights a fair bit, so it's probably fairly strong! Only removed due to full cage upgrade.
£20
rollbar
Heater matrix, centrifugal fan and housing. Complete heater assembly from Super Six (I may regret this when it gets cold...). Heater matrix sits in
bottom part of housing, fan draws air through this from passenger footwell and blows it through flexi hose (not inc.) to desired point of warmth.
Works pretty well. Comes with length of tatty "aeroquip" looking hose and blue blingy fitting.
£25
heater matrix
Tiger Super Six fibreglass pedal box cover. Tatty, with cutouts for cable exits. May be of use to someone - I've swapped to floor mounted pedals
so no good to me any more.
£5
pedal box cover
XR4x4i gearbox. This is a Type 9 'box with alloy bellhousing. Worked ok in the car before it was sacrificed for its parts. Has a long ratio 1st
gear that can be stolen for use in a normal 2wd Type 9, or use the alloy bellhousing to add lightness in a V6 installation. Or put it back in a
Sierra. Up to you really. No clutch fork (unless I manage to find it in the next couple of days!).
£50, collection only
xr4x4 box
Injectors. 2 sets from standard 2.0l silvertop zetecs (mk1 mondeo), one set from a Rover 220 Turbo which are capable of 220bhp and are a cheap upgrade
for vauxhall red top owners. All were working ok etc etc.
£5 per set, Rover ones sold
injectors
Fog light. Not much more to say, comes with a decent bracket and it's nice and bright.
£7.50
fog light
Oil cooler - 19 row Mocal, used and grubby on the outside but inlets plugged and clean (but oily!) on the inside - i.e it's not been used on an
engine that's blown up!
£15
oil cooler
Complete set of gauges - from Tiger Super Six. Speedo, Tacho, voltmeter, water temp, oil temp (not a matching gauge), clock and fue gauge. Speedo
looks like it will be easy to open and reset if you don't want it to show 11900-odd miles already. Comes with sensors for the temp gauges, a
speedo cable suitable for a type 9 gearbox, and bulbs for the internal illumination (one bulb and holder is missing though, sorry.).
£100 for the complete set
gauges 1
gauges 2
gauges 3
Caterham ARB - widetrack width, "Green" specification. Unused, but powder coat is a bit scratched. £47 new, so....
£30 seems fair?
ARB
All prices plus p&p at cost.
Cash on collection preferred for everything (mainly because I hate wrapping parcels!), especially for heavy stuff that'll give the postie a
hernia. Free cup of tea and a biscuit for all collection items by way of incentive.
Tom
[Edited on 4/5/11 by djtom]
Rover injectors please. Can you u2u me approx location in tunbridge wells see if I can collect
u2u re: heater
U2Us replied to
Tom
can i have the roll bar if it fits my standard book (ron champion) chassis?
Cheers U2u sent.
can you post though if possible?
Can I have first refusal on the oil cooler, gearbox and vice. Need to double check with team mates before committing but am after a long 1st gear type9!!
Quick update....
Vice provisionally sold to Imp Paul (pending payment)
Roll bar provisionally sold to Jossey (pending measurements and agreement of postage cost)
Rover injectors provisionally sold to Ben Copeland (pending collection arrangements / payment)
Speedstar wants oil cooler and gearbox pending consultation with team mates - I'll hold these for him until tomorrow am pending a response
(unless anyone turns up with loys of cash in the meantime!)
From a highly scientific twist of the input shaft, I believe the box has a 3.36:1 first gear, and from a quick google search it looks like you just
need to swap the tail housing for a normal 2wd one to turn it into a 2wd "close ratio" box.
Heater still available as Daddylonglegs has withdrawn interest.
Tom
Pedal box cover now sold,
£5 for the fog light? Not sure 100% it will suit but will take it for £5.
Kevin
Tom could I have second dibs on the vice please if it falls through.
Hugh
Hugh, the vice is yours if you want it, Paul pulled out and I've heard nothing back from Speedstar.
U2U me to arrange collection / postage / payment
Hogman, sorry, no deal at £5.
Rover injectors sold to Ben
Tom
[Edited on 5/5/11 by djtom]
