Ally fuel tank - fisher fury but may fit other kits too
henryc - 4/8/11 at 07:07 PM
Fuel tank from my Fisher Fury race car - aluminium with internal baffles, filler neck, hole for fuel sender (accepts Midget fuel sender or can be blanked off) and take off for breather/roll over valve (again, can be blanked off if not needed).
Filler neck is 50mm diameter, fuel outlet is 10mm diameter to allow high fuel flow. Overall size (mm) 145 x 320 x 662
There is a crack in one of the welds that has been sealed with chemical metal - it is currently fuel tight. The chemical metal could be removed and the seam re-welded, but I don't have the facilities to do this.
The tank has been sealed since removal, so is clean inside. Can be posted or picked up from Huddersfield or Pudsey.
I rather dumbly listed it on Ebay rather than posting it on here, but it's currently all of £20, so a bit of a bargain really:
Fisher Fury race car Fuel tank locost, kit car | eBay
Trollyjack - 4/8/11 at 07:20 PM
Any Idear if it would fit a Locost
