Westfield SEIW 216 Bhp Vx XE Engined
perksy - 9/1/12 at 08:05 PM
WESTFIELD SEIW - VAUXHALL XE POWERED
Below is the Specification of My Westfield that I’ve decided to sell
It’s abit early in the year to sell and I’m in no hurry, but we’ll see what happens
It would make a very nice upgrade for a current Westfield owner or a new owner who wants a high specification car to start with
It is the widebody version Westfield with independent suspension
The engine is dry sumped and the full spec includes a lot of SBD sourced
Parts
The chassis was purchased in 2003 from Westfield sports cars and the car was registered in August 2004
Registered on a ‘Q’ plate so no emissions issues at MOT (No Cat Fitted)
The engine was mapped by Troy at Northampton motorsport and Made 216 bhp & 176 lbft of Torque (Printout Available)
The car has covered 6600 miles and there is a Large A4 Ring Folder of Receipts Totalling over 20k
It can be seen on the SBD website in the customer cars section
http://sbdev.co.uk/Case_Studies/CaseStudies_MarkPerks.htm
And is also featured on Tiggers excellent website at http://westfield-world.com/pics_mark.html it has been seen in Westfield world magazine & Club calendars on several occasions
It was also shown on the WSCC stand at the Stoneleigh kit car show in 2009
It weighed in at 560kgs on the local council weighbridge
Price
£ 11, 595 ono
No timewasters please
The car has an agreed valuation of 14k (Letter supplied) and
Is located in Shropshire, West midlands
Email is the best way of getting in touch and I’m happy to answer any questions that are not covered in the specification below
Thanks for looking
Mark (Perksy)
Email: mark.perksy@btinternet.com
BODYWORK
WESTFIELD SEIW BODYWORK
POWDER COATED CHASSIS
RAC TYPE ROLL BAR WITH HIGH LEVEL BRAKE LIGHT
V8 BONNET
DETACHABLE REAR ARCHES
WESTFIELD CARBON LOOK REAR ARCH STONEGUARDS
ORANGE GRP BODY WITH BLACK NOSE / FRONT WHEEL ARCHES & AEROSCREEN
M & P HEADLAMPS
WESTFIELD CARBON EFFECT REAR LIGHTS
SPA CARBON FIBRE MIRRORS
FLUKE MOTORSPORT CARBON FIBRE BOOT COVER
CARBON FIBRE FOOTWELL COVER
ENGINE & RUNNING GEAR
VAUXHALL 2 LITRE XE ENGINE
SBD 225 SPEC ENGINE KIT FITTED
SBD TAPER DTH THROTTLE BODIES
SAAB TURBO ‘RED’ FUEL INJECTORS
MBE 967 ECU
87MM OMEGA HIGH COMPRESSION PISTONS
STEEL CON RODS
COSCAST CYLINDER HEAD
COMETIC STEEL LAYER HEADGASKET
ARP HEAD STUD KIT
SBD SPECIFICATION KENT CAMSHAFTS, SPRINGS, CAPS AND SPRING PLATFOMS
SBD VERNIER CAM PULLIES
SBD LIGHTWEIGHT SMALL ALTERNATOR
SBD (PACE) DRY SUMP OIL SYSTEM
SBD 4-2-1 EXHAUST MANIFOLD
SBD 7" X 26" REPACKABLE SILENCER (Repacked with Acoustafil Competition Packing)
SBD HEAVY DUTY ENGINE MOUNTS
CUSTOM MADE PERFORMANCE SPARKPLUG LEADS
LAMINOVA OIL / WATER COOLER
VW POLO RAD
ALL OIL / FUEL LINES IN ENGINE BAY FITTED WITH STAINLESS STEEL HOSE AND AEROQUIP FITTINGS
ODYSSEY PC 680 LIGHT WEIGHT BATTERY (Still Under Warranty)
MOCAL OIL CATCH TANK
HYDRAULIC CLUTCH
SBD HEAVY DUTY CLUTCH PLATE
SBD HEAVY DUTY CLUTCH COVER
SBD LIGHTENED STD FLYWHEEL
BGH GEARTECH TYPE 9 GEARBOX
WITH THE FOLLOWING RATIOS:
1st 2.66
2nd 1.75
3rd 1.26
4th 1.1
5th 0.84
WESTFIELD GEARLEVER EXTENSION KIT
3.92 FORD LSD DIFFERENTIAL
13” x 7” RIAL 3 PIECE SPLIT RIM ALLOY WHEELS (Very Light & Cost Over £230 a Wheel)
YOKOHAMA A021R 205/60 R13 TYRES (Rears have done less the 1000 miles)
AVO ADJUSTABLE SHOCK ABSORBERS
SEPARATE BRAKE MASTER CYLINDERS FOR FRONT & REAR WITH BALANCE BAR
FLOOR MOUNTED PEDAL ASSEMBLY
CAT MOTORSPORT 4 POT CALIPERS WITH MINTEX PADS
RACELEDA GROOVED & DRILLED FRONT DISCS
STANDARD WESTFIELD (FORD) FITMENT REAR BRAKE CALIPERS AND DISCS
CAT MOTORSPORT QUICK RACK
ALLOY FRONT HUBS
INTERIOR
WILLANS 4" 4 POINT SAFETY HARNESSES
GRP SEATS
PLAYSKOOL CARBON FIBRE DASH
VDO GAUGES FOR FUEL, OIL PRESSURE, OIL TEMP’ AND COOLANT TEMP’
LED SHIFT LIGHT AND LED LOW OIL PRESSURE WARNING LIGHT
SECURITY IMOBILISER (CAT 2 WITH INSURANCE CERTIFICATE)
TONNEAU COVER
HAND HELD FIRE EXTINGUISHER MOUNTED IN PASSENGER FOOTWELL
[Edited on 9/1/12 by perksy]
nick205 - 9/1/12 at 09:01 PM
Rather looking motor you have there - good luck with the sale.
scootz - 9/1/12 at 09:07 PM
Very
Good luck with the sale!
PAUL FISHER - 9/1/12 at 09:25 PM
ooh!! I like that
perksy - 10/1/12 at 06:43 PM
Thanks for the comments
Only covered about a 1000 miles in the last 2 years due to work etc
So its time to let it go
Still have abit of a soft spot for a Raw Striker though....
perksy - 22/1/12 at 04:39 PM
Deposit Taken
Nice chap from the Midlands who is also a first time Westfield buyer
