Hello all,
I've finally decided to sell my GSXR1000 throttle body setup. I had these running very well on my previous C20XE engine (sound great and very
responsive as you'd expect) and was going to fit them to my new zetec but decided to go down the plenum route instead. I was going to keep them
for a future upgrade but I could do with the cash so unfortunately they have to go.
The throttle bodies are somewhere between K1 & K3 year I believe and are the re-spaceable type. They have been respaced to suit C20XE but can
easily be adjusted by a few mm either way to suit a zetec or similar.
I have removed the secondary throttles and blanked / smoothed the holes, added machined spacers and throttle linkage extensions and also had some new
fuel rail sections made up to extend the original fuel rail properly.
The original GSXR injectors and TPS are present, as are the electrical connectors / loom and manifold vacuum pipes.
Also included are fuel-resistant, steel reinforced hose sections and jubilee clips for connecting to a manifold.
The throttle bodies also come with a pipercross sausage filter with custom backplate incorporating original GSXR rubber velocity stacks (all same
length) and a GSXR air temperature sensor. the filter has started to show a slight amount of weathering but is in excellent condition otherwise, as
are the rest of the components.
Was looking for 200 pounds for a quick sale
Sensible offers considered....
Hi, Is there a inlet manifold to go with these?
No, I've already sold the manifold unfortunately since I was converting over to a zetec and didn't need it!
hi there,
i already have these fitted but need the filter ,plate,rubbers if you split could you let me know
thanks
Hi, I'm going to try to keep these together so I can use them again if they don't sell (the backplate and trumpets took a while to make / find). Thanks anyway.
Last try before they go on ebay or I decide to keep them... now £150+postage.... bargain!
U2U sent
Now sold (subject to payment)
Chris
