Selling my Geartronics Gear Indicator Display with loom to fit a Hayabusa as I've just changed engines so its no longer needed. I will post some
photos later when I've ventured out to the garage
£100 inc post
is this just plug and play?
Does it read from the ecu or from the speedo/revs?
Hi
It plugs straight into the gear position centre loom on the Hayabusa. It also needs a live and earth. It reads the gear from the gearbox, so it's
more accurate than the speed/revs indicators
Many thanks
Duncan
Photo as promised, a bit late i know
£75 inc post
Hayabusa Geartronics Indicator
