Starting to have a bit of a clear out of all parts laying around in my garage.
BEC propshaft which is a modified sierra unit believed to be supplied by MK but I can't guarantee that. It has Sierra diff flange and BEC
sprocket adapter flange. Just had brand new centre bearing and rubber mount from Graham Goode.
Dimensions are........
Diff flange to centre of centre bearing approx 905mm
Centre of centre bearing to BEC adapter flange 485mm (retracted)
Same as above but extended 525mm
[img]
[/img]
[img]
[/img]
Looking for £60 Collected but willing to package it up if you want to arrange courier at your expense.
Escort type radiator. Overall dimensions including end caps 395x480mm. Inlet/Outlet 25mm diameter, bleed hose 8mm diameter. The bottom pipe has been
repaired with some sort of sealant in the past and has started to weep water, could really do with being repaired properly. Fan is included as
well.
[img]
[/img]
[img]
[/img]
££££ Offers on this as I'm not really sure what its worth given the condition. Looking at £10 postage.
hi do you have the flange that fits the bike engine side? if so what engine is it for
No I don't have the sprocket adapter. You can get them from various companies though.
Still available. BTTT.
Open to offers......its taking up space!
Prop shaft sold.
