Hi, for sale I have a 90k miles Audi 2.8 litre V6, 30 Valve quad cam, circa 230BHP. It is from an Audi A6 and includes a manual Quattro gearbox,
driveshafts, uprights etc and all engine ancillaries. You should be able to fire this up on the included AUDI standard ECU.
It was intended for A mid engine CANAM project, but unfortunately I've had to cut this project short for a while.
I've cleaned up the rocker covers, but otherwise the engine is untouched.
£280 ONO
Also available are 2 sets of Triumph 675 Street triple throttle bodies which I was planning to mount on top (need to make up some stub manifolds),
including TPS, injectors, fuel rails etc.
£80 ONO the pair ( I can do discount if you take the lot together)
Would be an ideal setup for a mid engine scratch build, especially as you could swap it for the twin turbop version, or the V8 at alater date.
Collection from Nottingham although I may be able to arrange a courier as it's all on a pallet (at buyers additional cost)
I can be reached via U2U on this forum as well as my mobile below.
Laurence
07796683133
[Edited on 13/8/14 by sylva_phoenix]
40 valves across 6 cylinders. Which ones got short changed?!
Ha, good point, yes it's a 30 Valve, not 40! Sorry for any confusion. Guess I was thinking about a v8, wonder why....?
