I am clearing out ready for moving house and have the following:
ZX9R carbs (not sure which model but maybe someone on here can enlighten me) I no longer have the Locost which I was going to use them on so no longer
needed.
£50 posted
Motorcraft coil and leads off Zetec.
£20 posted
SOLD Set of rear light units. One has no bulb holder - none have bulbs fitted.
£12 posted
SOLD Set of vacuum gauges and adaptors.
£35 posted
[pg]107137[/pg
SOLD Set of four Southco bonnet catches (the proper IVA ones).
£20 the set posted
SOLD Pair of 25mm wheel spacers. Ford 108 PCD
£10 posted
Thanks for looking.
[Edited on 20/10/14 by Daddylonglegs]
ill take the wheel spacers pm me details payment etc cheers
I think those carbs are CVR's, which should make them E model carbs if they are definitely off of a ZX9.
If you post the numbers/letters off of the end then I'm sure somebody will be able to confirm on here.
I'll take the rear lights, PM me with payment details. Cheers
Vac guages pls
Originally posted by snapper
Vac guages pls
Bonnet Catches please!
U2U on it's way!
u2u replied
Thanks guys
I can't see any numbers as such on the carbs, but they do have 'CVR' on each end.
[Edited on 21/10/14 by Daddylonglegs]
