discs/ caliper/hubs for sale
rj - 25/10/14 at 01:09 PM
I am having a bit of a clear out, I have the following I no longer need
M16 calipers with pads - plenty of meat on them, £45 the pair
Cortina 248 x 13 discs, never used, but need a bit of a clean up, £20 pair
Cortina hubs ( the bit that has the disc bolted on ) with slightly used 248 x 13 discs - now 12.5mm thick with bearings £45 pair
Sierra o/s stearing knuckle with bearings and hub £20
Rover 25 master cylinder, this mounts horizontal and has 2 outlets, reservoir with low fluid switch, good for IVA £15
I would prefer pick up, as they are all heavy to post, I live in S Yorks and work in W Yorks and get into Derbyshire at weekends if that helps
U2U or give me a call on 07443 428854 if interested. Richard
joneh - 26/10/14 at 07:29 AM
Hi,
Any pics or further details on the calipers and master cylinder?
Jon
rj - 27/10/14 at 07:11 PM
hi, I will try to post some pics, but last time I tried on here it didn't work ! ( I am not very good with computers ) if you let me have your email I will send them. Richard
