This is the sierra viscous LSD unit.
7 inch, push in shafts, with 3.92 ratio.
This has just been rebuilt by Phil at Road & Race with the comment ' that's a nice strong unit'...The only reason it's for
sale is that i swapped to a plate diff and had bought a spare 3.92 which was open ( hence the word open in the photo ) and a spare sierra slipper
'in case'...i had Phil marry the 2 up to make a decent LSD.
This is located 10 mins from Dartford Crossing or 10 mins from Sevenoaks - nr Brands Hatch.
photos as below - £365
That looks like bolt on shafts to me?
I'm sure I read somewhere that they can be changed between push in and bolt on? maybe I made that up, but im sure I didnt
7" Open diffs can take either push in or bolt on if the bolt on flange whafts are removed because the push in shafts and bolt on flange splines
are equal lengths.
On the lsd however, the splined lengths differ, so lsds are bolt on only of using ford oem viscous lsds
sorry guys, that's me being in a hurry! dead right, 'was' push in shafts, Phil obviously changed them!
