I'm selling this New 1800 K-Series engine to add to my garage rebuild fund, it was bought from Rover as a new engine.
It was trial fitted into a FF2000 to replace the pinto engine for hillclimbing but then pulled out before use as the chassis had become quite valuable
and the chassis was sold on.
As you know these are superb little lightweight engines that can produce 250+ odd hp with the right spec.
The engine has only been started and run stationary.
Spec -
1800 Non VVC Engine
Full dry sump kit
Direct to Head Jenvey Throttle Bodies, fuel rail and linkage kit.
Flywheel to Accept RWD application & AP Clutch
Omex 3D engine management with k-series base map.
Full engine loom.
Starter
Pair of Hillclimb / sprint experimental reg rind cams from a tuning company (can't quite remember who) these are included but not fitted to the
engine.
Pretty much a full car install apart from exhaust system.
The price is 2k including UK delivery.
[Edited on 20/7/15 by Benzo]
Bargain!
That is a bargain indeed!
L7C would be a good place to advertise
Too cheap? Lol
It's the guts of 4-5k of bits.
Too many projects on the go! Time to clear a few things out!
Is LC7 another forum?
Lotus 7 club or 'blatchat'
or seloc
Benzo, am interested, have sent a u2u, regards, John
Deposit taken!
