I have just taken these off my Striker mid build as I am a tart and changed to hi-spec alloy brakes
They have been fully serviced, undercoated and then powder coated. They come with the carriers and some part used pads. The non-standard parts are
reduced height handbrake springs and flexible brake pipes with stainless fittings and pipes (coated in a smoke grey plastic), both new. The bleed
valves have been changed to race spec one way valves to make bleeding a little easier These fitted under Team Dynamic 13" wheels
These were fitted and bleed before I changed my mind so I know they work perfectly well....I will drain the fluid before I send them out
I would like £100 plus delivery, the pipes and handbrake springs cost half that only a few months ago.
Now sold and paid for
