Zetec full exhaust system. Headers are OK but the standard silencer is a bit past it's sell by date (well I think so as it rattles with rust
inside it) anyway will chuck that in for free. You could cut the end off it and renew whatever and re-pack it? Just a note, have passed trackday noise
test with it so it may not be that bad.
I have the aluminium heat-shield for it but needs one of the welds re doing where the jubilee clips goes to fasten it to the silencer.
The headers are the standard Westfield 4 into 1 and will fit 1.8 Silvertop and 2.0 Blacktop engines as I have fitted then to the engines listed. It
also has tapping for sensor.
All the above for £100 collection only
Pic here https://lh3.googleusercontent.com/-JiQhfgtGpDE/VeMrpmkhfOI/AAAAAAAAI2M/pEYBfY83k0o/s640-Ic42/DSCF4352.JPG
Terry
[Edited on 9/1/16 by terryathome]
What is your location?
Do you have a picture as the link does not work?
https://lh3.googleusercontent.com/-gMseBT_U0a4/VpFYARvDm8I/AAAAAAAAJgk/dmI6vlPAPUw/s640-Ic42/DSCF4352.JPG
Should be able to see it, try the link above
Post code is BB9 location
you can't actually see the headers in the pic as the bonnet is closed
Here you go
https://lh3.googleusercontent.com/-pz5L1vsIaGw/Ubs8aC6BzcI/AAAAAAAAAsk/w4tRvXaoqgM/s640-Ic42/DSCF3257.JPG
Hopefully 2nd dibs on your exhaust? U2U sent also.
Dick, I can't see that anybody has said that they wanted the exhaust before your post but remember it's collection only and it looks like
your in Birmingham. What would you like to do?
Terry
Hi Did you manage to sell the exhaust, if not I will take it cheers Richard
Richard, Dick has first dibs. You have 2nd dibs.
SOLD
