Need to clear up some space so the following are up for grabs:
Pair of new rear wings for the 3 piece rear end - small notches cut for live could be covered by stone guard for IRS - £100 delivered
Used rear tub - no reasonable offer refused
Used bonnet - no reasonable offer refused
Used dash and deflector - no reasonable offer refused
One used chassis- may be of use to someone - open to offers
This has suffered a shunt to the near side front resulting in both bent and twisted front corner. Included will be the side apannels, tunnel sides and
rear "bulkhead" panel. (Reservoirs not included)
PM for more photos
All located at the west end of the M4 but may be able to help with delivery.
[Edited on 24/1/16 by Rich J]
any idea what uprights the wishbones are for? (Raw option lists specify Sierra ones as stand, but give no idea if they are different to capri versions.)
These are for the Escort uprights using a 3/4" UNF Sherpa track rod end. I would imagine they're the same as Capri
indeed, caprri shares the rs escort uprights. will take them- pm sent.
Wishbones arrived mate - Quick and beautifully packaged!
Thanks!
