AP radial mounted calipers - CP4567 comes with Machined mounting brackets bolts etc.
Would recommend new disc to bell fitting kit is used but old bolts are included.
Genuine 267mm x 21mm disc's just been checked, surfaced ground and returned from AP this week(will need to follow correct AP bedding in
procedure)
Mintex 144 pads nearly new cost £80.00
Some marks on the calipers etc which is to expected
Any inspection welcome
Reason for selling going for a more powerful AP brake setup
The only thing extra that will be needed to fit is the flexi hoses and caliper banjo bolt fittings
The Hubs/Wheel Nuts are not included
£850 ovno + £15.00 post (uk only please) collection preferred
Located near Dover Kent
Link to Motorsport tools
Escort Mk1 & Mk2 AP Forest Radial CP4567 Brake kit 267 x 21mm - 13" Wheel
[Edited on 26/3/16 by Digimon]
Hi, are these still available?
Hi,
No sorry
