Smiths 3 wire tacho for 4, 6 or the magnificent 8 cylinder motor
rear view
£45 posted unless you live in some God forsaken but scenic region where the post office charge extra
Unused Tim ammeter still in box £12 posted as above
set of 4 gauges in dinky bit of plastic, £50 posted as shown, (there is also a duplicate oil pressure gauge if you need an extra matching one for say
fitting in the engine bay)
here is a rear view of the above 4 gauges ignore the other stuff in picture
Assorted gauges £10 each posted including the very colourful vacuum gauge
Princess 4 pots with link pipes etc good but heavy £112 posted, beautiful colour, obviously most of the price is carriage
Hopefully the info below will be good for someone looking at the calipers
I have Princess caliper's on my 7, with green stuff pads
They are a direct replacement for M16 on the Cortina stub axle, but are quite a bit heavier than the standard M16
Best to use 257mm discs (I don't) as use standard Cortina discs, but the pad will overhang the disc a few mm, but is not a problem
steve
Thanks for that, can also be widened to take thicker discs, spacers on e bay for about £30. A cheap up grade if your engine/ car needs it.
Princess calipers gone other stuff still available
