as above, i ordered this from ETB instruments but it was too short for my tank
VDO dip-tube fuel level sensors consist of a float inside a 40mm diameter vertical tube. Small holes at the top and bottom of the tube act as a baffle
to fuel sloshing around in the fuel tank.
The resistance range varies at empty depending on the length but are between 60 & 90 ohms at empty to approximately 2 to 5 ohms full. The sensor
matches the VDO fuel gauges or the ETB fuel gauge (digi dash' etc)
5 (unequally spaced) bolt holes on a 54mm P.C.D, 41mm cut out
£45 posted U.K. Mainland
[Edited on 13/1/17 by flanders]
[Edited on 14/1/17 by flanders]
U2u sent
Still for sale
Sold
