Hi guys,
Testing the water with this one at the moment as I had planned on keeping it for the rest of summer but things change and an opportunity has cropped
up so we shall see what happens, Happy to hang onto it but space isn't something I'm blessed with.
The car has just been checked over, Geo'd and cornerweighted by Dave Gallop at Track developments,
I'd ideally like to sell as a complete car minus engine, power commander, engine side wiring loom and Quantum suspension,
For the right money I'd sell complete minus the suspension.
Spec is as follows
AB Arion S1 development car as driven by Steve Bell - the car has won races in 750mc RGB series
Chassis/Drivetrain
Lightweight Arion S1 chassis with integral T45 cage
Raceleda front uprights
Billet alloy front hubs
Front anti roll bar
Wilwood calipers front and rear
Wilwood master cylinders
Titan Brake bias adjuster
Protech suspension
2.4 turn quickrack
Driveshafts built up on race CV joints (pair)
TRT Propshaft
Bodywork
AB Performance Arion bodywork
Front and rear clams removable in seconds
AB Performance wind screens
AB Performance rear spoiler
AB Performance Headlight covers
Exhaust
AB Performance 4-2-1 Exhaust system
AB Performance stainless 6 inch silencer
Cooling system
Radtec multi pass alloy radiator
AB performace/Mocal oil cooler kit
Davis Craig electric water pump
Davis Craig water pump controller
Rad and Oil cooler heavily ducted
Electronics
AIM Pista dash and data logger
AIM GPS Module
AIM Channel expander
AIM Memory key
AIM Rev pickup patch lead
VDO sensors used for Oil and Water temp and Oil pressure
Dynojet Power commander 5
LED Rear lights
Redtop lightweight battery
Interior
AB Performance GRP Narrow seats
AB Performance Paddleshift (cable operated)
Lifeline 2.25ltr fire extinguisher
Sparco Suede wheel
Lifeline steering boss
Wheels/Tyres
13" x 7j Compomotive CXR front
13" x 7j Compomotive CXR Rear
Michelin slicks alround
Summary
Car was stripped down by Andy and then sold to Scootz on the forum, Before collecting the car, In typical Scott fashion he sold the car on to me,
I've put the car back together replacing everything that showed signs of wear,
Brand new items included
brake lines
fuel lines
wheel bearings
wheel nuts
throttle and clutch cables
radiator
oil cooler kit
lifeline boss
TRS straps
Lifeline extinguisher
Seats
Bodywork
lights
oil and water temp and pressure sensors
etc etc etc
The full car was rewired by someone who knows what they're doing.
There's likely to be somethings I've forgotten so If there's anything you'd like clarifying then please get in touch.
The car is complete at the moment and will stay complete until a buyer is found, If someone's genuinely interested we can do a track day to give
you a feel for the car and the engine etc can be removed afterwards.
drop me a message to discuss price and so on.. many more pictures on request..
f someone want's a lesser spec or plans a road car build then I'm happy to discuss removing parts etc.
[Edited on 18/4/17 by gaz_gaz]
Good luck with the sale Garry, you can tell me what you are looking to get offline...
Thanks Jeff.
All u2u replied to.
To answer a few questions I've been asked a few times.
The car does not come with Protech or any other dampers and springs.
The car is wrapped, Not painted. It's completely white under the wrap.
bumping this back up.
Complete car ready to go and be enjoyed.
Just in the process of changing job so time for trackdays will be limited,
I'd be interested in a deal for a road registered car I can commute in when the weather allows
£12k which is less than half what It's had spent on it.
