The clearout continues!
4x sports cats:
1x small. 65mm DIA x 85mm long. Low cell count so may be marginal for MOT pass on larger engines..
1x medium. 94mm dia x 106mm long. brand new and 140g loading which is high so should be fine for MOT pass even on larger engines.
2x large. welded into housings. 94mm dia. 50mm inner dia entry and exits. 260mm total length. One of the housings has a threaded boss for lambda
sensor installation.
Stainless steel exhaust clamps by MPC - made in the EU, these are extremely high quality the best I have found. Much better than the Chinese rubbish
on ebay, I've never had one fail.
3x 52-55mm
3x 42-47mm
Titanium exhaust - from some sort of Suzuki V-twin I think. It has been a bit chopped about as I used one pipe to make an extremely lightweight fuel
filler pipe on a Lotus Exige a few years ago!! Ideal for similar projects or for titanium welding. Includes a titanium cast housing with butterfly
valve in it (Cable operated - any throttle cable linkage can easily be made to fit)
Prices
£6 posted small cat
£8.50 posted medium cat
£11 posted for each large cat.
£4 posted for each stainless clamp
£15 posted for titanium system
or £43 (plus postage) for the whole lot - I will give it a few days before accepting offers for individual bits as I'd much rather the reduced
hassle of selling all in one go.
Collection welcome from LE10 (Leicestershire)
cheers,
Pat
I'll take the 2 large cats if you do sell seperately.
As the previous, I'll take the medium cat if you sell separately
Craig
one last bump for the whole lot anyone...?
otherwise I will accept the offers above
medium and two large cats sold.
open to offers on remainder...
bump only small cat, titainium pipe, 3x 42-47 clamps and 2x 52-55 clamps left - £10 for the lot if you can collect!
LE10 Hinckley
bump
Interested in the clamps at that price, if you'll consider posting them?
I'll take small cat mate
