Sylva Stylus / Fisher Fury Roll Bar
se7ensport - 7/10/17 at 08:37 PM
I had this bar made by Fisher Fury back in 2008 (can't remember the name of the company back then). It's 2inch taller than normal and by using two steel angles it bolts straight into a Stylus, the chassis are / were the same at the contact points.
It leans forward by ~7degrees and is the highest bar that will fit under an original Stylus hood (which coincidentally I also have for sale).
Collect from Bristol, £120.
[img] Roll Bar
Roll Bar
[/img]
[img] Roll Bar 2
Roll Bar 2
[/img]
[img] Rear & toyo 888
Rear & toyo 888
[/img]
[img] side
side
[/img]
joneh - 8/10/17 at 12:26 PM
Hi,
If you get no takers that work for you, any chance you'd courier it? I'm assuming it'll fit a fisher fury.
I'm near Southampton. SO31.
Thanks,
Jon
