These need to go.
1 x Rover V8 3.5
* Ran perfectly fine when last used - might have the SVA emissions test certificate somewhere
* Has been stood in the garage for the last 5 years, but filled with oil and sealed. Drained the oil to normal level, turns over okay, but would def
recommend overhaul. Needs core plugs for a start.
* Engine No. 11A61056
* Also requires flywheel and Carbs
4 x Rover V8 exhaust manifolds
* No idea what these are off. I believe one pair is meant a for a DAX but not sure. No idea on the other pair. Both steel.
I have a load of pictures so send me a U2U message if you want to the pics sending.
Make me an offer
u2u'd
U2U'd as well.
