1) C20XE Low Profile Sump - OE trimmed and plate welded to 112mm depth (from block face) - from my Luego which is getting dry sump'ed -
cosmetically it looks a bit meh but it didn't ever leak which seems like a minor miracle for an XE sump.
£25
2) Set of 4x 1.9" ID 200mm length springs, 2x 300 and 2 x 200 lb/inch rate - black powder coated - also run 8k miles on my Luego
£30
3) Early type Lightweight Steel C20XE flywheel - I think it's a Turbosport one? Came off my spare engine/gearbox - which I'm building into a
(moderate) monster but I already had a Findaza flywheel and Helix clutch so it's surplus....surface feels okay but I recon it could do with a
skim
£50
Pick up from Southampton. Delivery is prolly about £10-15 in the UK but shout if you want and I'll confirm
If you want more pics, measurements or to come and check them out you're welcome - just let me know.
Will you split the springs, I only need the 300lb ones.
Springs are sold pending payment....
...and the flywheel is a Turbosport 3.6kg one -->
http://www.billetflywheel.com/product/opelvauxhall-c20xe-c20le
t-billet-flywheel-2/
Flywheel sold
Sump still available - should of mentioned it comes with the oil pickup pipe
