I collected together an mx5 donor package with the intention of building the Midlana.
This was three years ago and I am no nearer to starting. So with other projects that will keep busy for the forseable it’s time to Let the Midlana
dream go.
I have,
A pair of mk1 non abs front uprights that have been cleaned. They have one sheared bolt in each from the stone guards.
A pair of mk2 non abs rear uprights that have been cleaned. The top rubber bushes are shot but these would be replaced with bearings in a midlana.
New pair of hub seals.
A pair of mk2 drive shafts
A steering column.
A mk2 manual steering rack.
A set of four mk2 1.8 calipers and carriers and discs. All cleaned and ready for a rebuild.
The Midlana first edition book.
This would be collection only due to weight.
£200 or I may be open to a trade for Sierra bassed kitcar donor parts.
Bump...
I will keep the book and reduce the donor parts to £120.. as I need the space.
U2U sent
And replied, how’s that st170 conversion going mate ?
It's a rolling chassis with everything fitted except bodywork and wiring loom. Next job is to fit wiring loom and ecu and fire it up - I'll get a picture and post it in the next ew days and maybe one in a couple of weeks with engine running !!
If you were closer....
Yep I know but it's to much to post and I am just not around in the day time for a pallet courier.
