To be removed from my own car.
2.0 ST170 zetec, 12.1 wossner high compression pistons, williams racing steel rods with ARP bolts, ported and polished skimmed head, ARP Head stud
kit CAT Cams with verniers and VVT delete, crankcase breather on block moved to rocker cover, comes with one off inlet manifold and honda blackbird
throttle bodies, 4 branch exhaust manifold, flywheel, clutch and rwd sump. Still in car so can be heard running, done less that 2000 miles since i
built it, done less than 50 miles since head removed, reshimmed and valves recut, steel head gasket. Runs perfect. Made 197bhp on rollers with a safe
map.
£3200 ono.
Viewing welcome.
Could also include DTA S40 ECU and bespoke loom to run this engine at extra cost.
[Edited on 10/9/18 by RWD Focus]
