4.0L engine, needs rebore, have a set of 3.9 conrods, plan was to grind the big end journals to 3.9 std, snd use the 3.9 rods with oversize 3.9
pistons, all easily doable, 3.9 and 4.0 share bore size, but 4.0L gudgeon pins are offset and oversize pistons very scarce. Nice clean heads, no black
tar, plain SD1 type valve covers, heads are off. New water pump.
LT77 5 Speed suffix B gearbox, again nice and clean, looks little used after a rebuild.
Bellhousing and gear lever remote.
Refaced SD1 flywheel, Clutch, arm, slave cyl etc.
THOR and GEMS inlets.
There's a 390 Holley carb, and an unfinished modded inlet manifold too.
Coils, pulleys, spare sump, front cover, 36:1 Trigger wheel.
Looking for £800 the lot, these gearboxes are going for silly money now without bellhousings and gear lever remotes, Car Flywheels aren't too
plentiful either..
I'm close by M1 J31.
[Edited on 11/11/19 by r1_pete]
