Weber twin 40 DCOE carbs on Zetec manifold. I rebuilt the carbs approx 4 years ago. They were ultrasonic cleaned at the time and all new seals fitted.
last year i fitted new gaskets for between the carbs and the inlet manifold with the correct rubber washers also. New bottom mounted linkage was also
installed last year. All mounted on a Zetec inlet manifold. Pipercross individual sock filters.
Going over to TB's so no longer required. They were jetted correctly for a 1800 Zetec on the rollers and have always performed well.
Looking for £550 as a complete setup.
will go on ebay at the weekend if no interest here...
