Hi all,
Relating to the 3.38 diff I advertised before, I've now found the driveshafts to go with it, they're push-in, they're complete, and
they have the drum brake flanges on the end (i.e. with the 4 bolt holes, not the 2 extra bolt holes to mount calipers).
They're a bit dusty having sat in a garage, but they seem complete and in good nick.
Also - I need to check the ratio again, I turned it by hand and counted about 3.38, my Dad did the same thing and reckons it's 3.14, so I need to
go out and check it again very carefully, but it's definitely a ratio less than 3.5!
I'll also take a couple of extra photos later today if anyone's interested.
If anyone wants the set of diff & driveshafts complete, let's say £150.
I'd guess postage will be fairly expensive (maybe £40 ish?) as it'll be heavy, so collection from Stone, Staffs is probably easier, but
i'll look into it if needed.
Ad
Have you still got it?
best way to check the ratio is to do it over 10 turns of the input or more.
....but it is a bit chilly in the garage....
I do still have them. Are you interested?
If so, i'll venture out there and try to settle it once & for all!
Ad
yes interested but ok for a few weeks - wait 'til convenient then U2U me
No problem, will do
Ad
