Hispec rear callipers, Ford fit
Twobeers - 15/2/24 at 12:20 AM
Used for around 10 hours (6 race weekends) in a Ginetta G20.
These are as the link below, Ultralite 2 (UL2 FREAR) anodised black and are designed as a direct replacement for standard Ford Sierra rear hubs, ie, 2 lugs.
I've gone to a completely different rear disc set up and have replaced these with the same but in a radial mount pattern. Hispec weren't the easiest to deal with but to be fair we've never had a problem with their products. £200.
http://www.hispeccalipers.co.uk/ultralite-2.html
I also have a set of alloy hubs to take 273mm discs (not the standard 253mm) so slightly longer ears. Complete with bearings and seals and used for one race weekend. Also, a pair of 273mm discs to suit these, again used for 3 track sessions. Gone to a different set up so no longer required. £150 for the hubs, £40 for the discs.
wowblaauw - 17/2/24 at 11:51 AM
Hi, I'm interested in this whole setup. Where are you based?
Twobeers - 17/2/24 at 06:54 PM
Hi, I'm based in Chipstead, Surrey. For clarification and in response to another enquiry, these are without hand brake mechanisms.
wowblaauw - 17/2/24 at 07:20 PM
Ok and thanks, I'll be giving these a miss - good luck with the sale
roadrunner - 19/2/24 at 10:01 AM
Hi.
Is there a way to fit handbrake with theses calipers.
Brad
Twobeers - 19/2/24 at 12:14 PM
No, the version with the handbrake option is completely different, this version is purely a caliper. Hispec do a separate handbrake only system if that's any help.
roadrunner - 19/2/24 at 03:34 PM
frodo_monkey - 28/3/24 at 10:25 PM
Are these still available?
Twobeers - 28/3/24 at 11:47 PM
Yep, still available.
frodo_monkey - 29/3/24 at 01:28 PM
u2u sent!
Twobeers - 2/4/24 at 03:36 PM
Calipers sold, hubs and discs still available
wrayvon - 3/4/24 at 08:13 AM
Not wanting to take over the thread but if anyone else was after some calipers I also have a set. Feel free to PM me.
