Locost chassis project unfinished.**CHEAP**
Up for sale is my unfinished Locost project. Starting new job in Jan so no time/money to complete.
Chassis:
Complete except for the bar that fits under the scuttle that holds the sierra steering column. Made the hoop but needs welding on. Only other things
that need welding are the threaded harness bolt holes/tubes which come supplied. Also supplied are the GTS front top and bottom wishbones including
ball joints, Rear trailing arms, Sierra brake master cylinder, steering column, handbrake lever/cable and pedals.
There is a new ally floor fitted plus panel behind where the seats go. Also supplied is the ally to make the remainder of the sides and rear
panel.
Chassis is set up to take a Ford Xflow engine but these mounts can be removed easily for your choice of car or bike engine. Chassis is painted
black.
Bodywork:
Supplied are the scuttle [has holes for de mister and windscreen wipers], Bonnet, nosecone and front/back arches. Rear arches have lights. All need a
good wash and polish.
Chassis and all parts will need to be taken away on a trailer for obvious reasons.
Chassis in Warlingham, 5 mins from J6 M25
£150
[Edited on 16/12/07 by donut]
you have email .
You have a u2u!
Provisionally sold
45 minutes yet another record andy
glad i don't disappoint!
Sorry to see that Donut.. unless you made another car, you've been going even longer than me without finishing :/
Nah the real problem is Donut just doesn't have a clue what he's doing most of the time
quote:Oh how true
