Wide Rose Jointed Wide Track Wishbones
chazpowerslide - 4/2/08 at 10:09 PM
I have for sale a complete set of wide track (+80mm) wishbones to suit the book chassis.
The wishbones are 8 months old and in very good condition.
These are constructed from 3/4" CFS360NBK cold drawn seemless tubing with a 2mm wall thickness and are powdercoated in satin balck.
The lower wishbone plates and bottom damper mount were from MNR racing and are plenty beefy so they will not bend.
The rose joints are heavy duty 7/16" bore and 7/16" stub from the National range and have done less than 1000 miles.
The top ball joints are on aluminium Micro Camber Adjusters.
You get;
2 x top wishbones.
2 x top ball joints (used/good condition)
2 x aluminium micro camber adjusters
2 x lower wishbones
2 x Maxi bottom ball joints (used/good condition
2 x MNR aluminium rack extensions.
8 x 7/16" x 7/16" heavy duty National rod ends.
All the fasteners/lock nuts ect
2 x jigs should you need to make up another set.
Bearing in mind the rod ends alone were £18 each (£144 for the lot) and the Micro camber adjusters were £20 each.
I rekon that £175 plus carridge is a fair price to ask.
I can be contacted bu U2U/Email on on this thread.
Chaz
COREdevelopments - 4/2/08 at 10:11 PM
now thats a good deal for someone,
Rob
chazpowerslide - 7/2/08 at 09:34 PM
Thanks Rob.
Chaz.
alfasudsprint - 11/2/08 at 04:40 PM
Which uprights are they designed for m8? raceleda tina or sierra?
chazpowerslide - 12/2/08 at 10:13 PM
They are for Cortina uprights.
Chaz.
