very cheap tin top
mcerd1 - 20/4/08 at 12:25 PM
My everyday car for the last 4.5 years
Pug 106,
its a silver 92' K reg 1.0 XN (105k on the clock) with 4 speed box and a carb
its a very basic car, and its not perfect but is taxed and tested till the end of october - it could have a few years left in it yet
£150 (inc tax)
mangogrooveworkshop - 20/4/08 at 12:29 PM
bring it over we will have a look, you will have a deal If it will make it to Italy and back.
u2u
[Edited on 20-4-08 by mangogrooveworkshop]
mangogrooveworkshop - 20/4/08 at 12:47 PM
mangogrooveworkshop - 20/4/08 at 12:53 PM
well thats it just need passport to get things done
tegwin - 20/4/08 at 01:25 PM
http://www.rust2rome.com/rust2rome-images/gallery/gallery-ps/DSCF6407.jpg
mcerd1 - 20/4/08 at 02:30 PM
so who's all going ?
and more importantly - do I take the car to fife or swanston ??
(it's back on my insurance for Mon, Tue, Wed this week)
ps - heres some pics:
(couple of years ago)
(today)
[Edited on 20/4/08 by mcerd1]
mangogrooveworkshop - 21/4/08 at 10:27 AM
Just bring it over to Fife and I will give you the cash. Im working on the theroy that if it can make it to fife it should make it to ITALY and back lol
mcerd1 - 21/4/08 at 12:09 PM
I got the car with 60k on it as an MOT failure for £450 (it was a trade-in at a local garage)
here's a quick run through of the bits I've replaced over the years:
oil + filter every 5K (castrol GTX)
air filter every 10k
plugs gapped every 5k - replaced every 10 - 15k
front suspension ball joints and bushes when needed (done a few times now )
bushes are now all Pug genuine parts (they last longer)
{btw - these are easy to do if you have a press, and remove the arm from the car}
60k - new fuel sender
65k - 4x Driveshaft boots (still look good)
70k - rear dampers
80k - timing + fan belts
90k - new clutch
95k - Front brakes (recon calipers, new flexibles, new discs)
- Rear brakes (new drums, new wheels bearings, new shoes, new handbrake linkage)
- new Front dampers and springs
- new exhaust system (there is only 1 pipe + 1 box)
100k - new track rod ends
- Service (air filter, oil + filter, new plugs)
103k - Front wheel bearings
- s/h gearbox (from 59k car)
- driveshaft oil seals
- new gear oil
104k - new ignition amp
- new coil
- new dizzy cap + rotor arm
- new HT leads
- replaced last section of fuel pipe onto carb
some things have been done more than once, but I've only listed the last time it was done
[Edited on 21/4/08 by mcerd1]
mangogrooveworkshop - 21/4/08 at 12:38 PM
Sounds like the right car for the run to the sun....... dont know where we fit the press in macs hand lugguage
mcerd1 - 21/4/08 at 01:03 PM
there is no way I'd have done all that if I wasn't planning to keep the car - but plans change
if you add up all the parts - on average I've spent about £250 - 300 a year on the car.....
...which is about the same as its average value over the same time
so there can't be much left to replace
mcerd1 - 23/4/08 at 12:41 PM
Sold
have fun in Rome
[Edited on 23/4/08 by mcerd1]
mangogrooveworkshop - 27/4/08 at 08:11 PM
Now the proud owner link
mangogrooveworkshop - 26/6/08 at 08:55 AM
Rally update, for google archives
This little car went to Rome and back covering an incredible 4250 mile in the 14 days. Without missing a beat Still bieng used as my daily driver
