Fits neatly inside the can end, doesn't protrude like the perforated straight tube veriety common on fleabay.
£7.50 inc P&P
[Edited on 13/6/08 by r1_pete]
First dibs
How much of a difference does it make?
And how is it fitted?
[Edited on 12/6/08 by tegwin]
It's a bargain.
It does quieten the pipe a little maybe about 15-20%, you need to drill a 6mm hole in the outlet pipe on the can, then it screws in via the bolt in the bracket on the left hand side in the picture.
