As you might or might not know. I have made up some locost badges. (see thred in body and ext)
I have cast a few sets up in white metal, painted them and have some for sale.
£25 front and rear set inc post
or
£14 for either design inc post
U2U if interested
Thanks.
Gaz
I'm Interested.
But what are the DImensions please?
whoops.
I could never win the apprentice
Round one 52mm dia
rectangular one 92mm long
I will take some better pics with a ruler
Gaz
front
and the rear
Gaz, is that black paint or could they come with bare primer, would they be ok to flood fill with thin paint is that how you've done these if
that is indeed black paint. Thinking about it you've probably just painted them and the sanded the tops to leave it shiney.
Cheers Rich
[Edited on 30/6/08 by RichardK]
they look pretty smart
Hi Rich,
I finished the ones in the pic by spraying the whole thing satin black then sanding the paint off the raised surface with 1200 grit (in one direction)
and then i laquered the surface, its alot easier then flooding.
If you want them in primer you can.
Gaz
whats on the back of them - ie how do you mount them?
I have tryed to cover all the bases as far as fitting them.
There are two 3.2mm pins on the back of each badge so you can drill two small holes to locate the pins on the body.
You can run a die down the pins and use small nuts to bolt them on.
you could crush the ends of the pins to fatten them once the pins are through the holes and use a little epoxy on the ends.
or you could cut the pins off and use mounting tape to stick them on. (my favorite)
I hope this is of some use.
Gaz
Go on the Gaz I'll take a set, can I have mine bare, I'll sort the priming and painting.
Cheers let me know how you want paying.
Rich
I have got to go to the post office on sat so i will post them then.
Thanks. gaz
Sorry to be a pain, but could anyone who contacted 907 via u2u about the badges u2u me.
Hi Gaz
You have a U2U with a list of people that U2U'd me.
Dad
