Hi guys,
i have recently change engine from a silvertop to a duratec lump. Yesterday i did pretty hard break test. This little test made the oil pressure to
drop. I have a warning lamp and a guage with separate senders. both indicate low oil pressure
I have a raceline wetsump and i checked the oil level before i left home.
Has anyone has the same problem with this sump?
No direct help but ours is a home modified one I found on EBay, haven't noticed the light come on or seen the gauge drop under breaking
but tonight I did notice the oil pressure was down to just over 10psi when warm at Idle but did soon rise with the rev's.
Is the warning light sencor the Duratec one? (just incase you'd re-used the zetec one which could come on at a different pressure)
Idle pressure is quite low on the duratec, IIRC that mine would idle at about 12-14psi with 5w40 fully synthetic oil, which is normal. I can check my
datalogs if you like and see what I was getting. I know it was well within spec.
Shouldn't drop under braking though...
Isn't that problem suposed to be prevented by the baffles in the sump.
Any idea what pressure the warning lights come on at?
My engine runs at low pressure compared to some so I rang BMW to see what pressure the switch comes on at after reading about redtops making 60psi at
idle.... 7psi for an m3 engine!
Maybe if you rang ford they could tell you?
Hi,
Under normal driving i have round 2,6-3 bars (38-43,5 PSI) in oil pressure. idle Pressure is quite low, same as Davids.
I shall check the oil pressure switch today and see if i can get the trigger pressure. I had some trouble to find a good sender and i think i ended
upp with an Volvo one so it might be the sender that triggers to "early"
Ours idles just under 20psi at 80degs oil temp. With a max of 55-60psi at high revs. Thats on semi synth 5-30 I think.
mine idles at about 1 bar stinking hot after a good thrash
3 bar driving, and 5 or 6 bar cold
Never had a problem with mine and highly rated by others. If you haven't already done so suggest you give Chris or Pete at Raceline a call - they're very helpfull.
Today I finished the wiring, put some oil, remove plugs and crank the engine to check the starter. I got some small black particles of carbon from the
cylinders (Is this OK from a 10K miles engine?) and got about 30psi of oil pressure. I don't know if this oil pressure is OK while only cranking
the engine (5w40 synth oil).
I will try to finish the exhaust this week and try to start the engine
[Edited on 29/7/12 by Nitrogeno25]
FASTdan I read a lot of sites talking about 85, 90 and 100 psi in the duratec (high revs). Does anybody know what specs is the oil pump relief valve in this engines?
Thanks!
I get similar pressures to FASTdan.
Not necessarily relevant but Chris at Raceline recommended 10w40 - especially for track use.
Hi guys
Ive been reading this thread with interest since Ive just got my duratec started and have been looking to see if it is running ok.
My first concern is with the oil pressure, It is running much higher than I would have expected but then I havent really let the car get up to proper
temp yet.
From cold the pressure gauge is reading approx 4.5 bar but then drops to about 3.5 as it gets a little warmer
How long would you expect it to take the engine oil to reach operating temp when sitting at idle?
I plan to start it tonight and leave it running for a while to see if the pressure drops anymore, hopefully it is just because i havent let it get hot
enough yet.
The next thing is that it seems to be very smokey and smells quite a bit,
The engine was taken apart and looked to be in very good condition.
new valve stem seals were fitted along with cleaning up the head and pistons, hopefully I havent cocked something up
My old pinto used to burn oil like mad and smoke a lot too so its possible that there is a large amount of crap built up in the exhaust, Im hoping
this may be the reason for the smell and the smoke.
The engine is only running on a base map at the moment too so is it possible it will be running to rich? again creating more smoke than normal?
I wouldn't worry about your high pressure (4.5 bar idle at cold doesnt seem unreasonable) - cold oil runs much higher than hot. I'd expect
15 minutes idle before you were up to 80degs (often the temp for quoted oil pressures). Oil warms slower than coolant generally so you cant rely on
coolant gauge temps (which might only take 5-10mins to be up at 80degs).
Is your smoke black (fuel) or blue (oil)?
[Edited on 31/7/12 by FASTdan]
Thanks for the quick reply Dan.
Thats good, Ill leave it running for a good 20-30 mins tonight and see what the oil pressure does.
I cant tell what the coolent temp is at the moment because my gauge isnt working for some reason (another thing to sort out)
The smoke is definitely very black....and sooty
hopefully that is the case, I dont have any kind of lambda installed.
I have a boss that a narrow band lambda can be fitted to , but the guys who will be mapping the engine for me advised me that I wouldnt need it.
I could try plugging the ecu in tonight and playing about with the settings.
But I think ill just wait until its on the rolling road.
I had that problem. Mine was running much to rich and hence the smoke. A session of the R/R sorted it nicely.
What about under harsh braking - any pressure drop at all? And what sump set-up?
Thanks for the raceline info - I think we were running whatever the std spec duratec oil is (possibly 5-30?).
We were seeing oil temps of 105degs on track after about 6 laps of blyton - no oil cooler (next mod!).
