Duratec to type 9. ( why a st150 flywheel)
ryanill - 13/1/14 at 07:13 PM
Hi all
Think that the title pretty much gives this one away
I'm in the planning stages of a duratec build. I Searched the forum for whitch clutch parts to use to join it with a type 9.Just wondering why it has to be a st150 flywheel.
Can a STD flywheel not be fitted ? As a st150 engine is a duratec ?
How is the st150 flywheel different to a everyday 2.0 duratec flywheel ?
Cheers guys
Ryan
big_wasa - 13/1/14 at 07:18 PM
Single mass ie solid as apposed to a dual mass flywheel found on the others.
ryanill - 13/1/14 at 07:29 PM
Std fly wheel = dule mass
St150 fly wheel = solid once pice .
Glad that was resolved quickly
Ryan
big-vee-twin - 13/1/14 at 07:47 PM
You can use an early Zetec flywheel also.
ryanill - 13/1/14 at 07:50 PM
Ah that's a useful bit of info too. Any ideas of the years that the zetechs where fitted with that type ?
big_wasa - 13/1/14 at 08:29 PM
That's a new one on me but the zetec E is the same for all of them. From the Silvertops to the Blacktops and these fit the st170, that's badged as a Duratec but isn't ?
ceebmoj - 13/1/14 at 09:40 PM
I think that flackmonky said on his build thread that the st150 fly wheel in only 1 of 2 kg heavier than the litend ones as well.
Dusty - 13/1/14 at 09:42 PM
ST170 Badged as a duratec but a zetec bottom end and zetec-ish head.
[Edited on 13/1/14 by Dusty]
big-vee-twin - 13/1/14 at 10:24 PM
Here's the part number for the fly wheel, taken from Flaks write up, so you can look it up.
[img] flywheel
flywheel
[/img]
[Edited on 13/1/14 by big-vee-twin]
ryanill - 14/1/14 at 06:23 AM
So is it the st170 (zetec) flywheel that also works aswell as the st150 ?
Also thanks for the number big-vee-twin. Just to clarify is that the zetec flywheel part number ?
Cheers fir all the info guys I know this is a subject that's been talked about Befor
big-vee-twin - 14/1/14 at 10:30 AM
I have looked through my notes, following BW comment, its the clutch pressure plate and not flywheel that can come from early Zetec.
Although I am sure that fly must be fitted to different engines.
big_wasa - 14/1/14 at 11:18 AM
The st170 flywheel is dual mass as well.
