Some of you know that i am having issues with my 1.8 (1996 spec) K series off a lotus elise. The 1.8 flywheel is too big for the caterham bellhousing
I have.
It has been pointed out to me that I will also have issues with the timing marks on any replacement flywheel I try.
So...I wondered if it might be a workable idea to have my 1.8 flywheel machined down to the same radius as a 1.6 and use the ring gear off the 1.6.
This way I will have the correct timing marks. As long as they do not fall within the area to be machined.
Any ideas??
Just to give you another option, the reluctor ring that contains the flywheel code CAN be removed from the flywheel - but it's not easy. I
removed mine to change the code to a 36-1 pattern to suit megajolt, in my case this involved welding a couple of extra tabs to the reluctor ring. So
it *may* be possible for you to change these rings over.
From memory the one on my 10" flywheel was held in with 4 tabs accessed from the back of the flywheel. I punched these through and levered the
ring out. It looked pretty sorry for itself by now, but was made from a fairly soft material and straightened up easily. As mentioned, I then had to
add a couple of extra tabs, and tap the ring back into the flywheel.
I did this to remove the need for a 36-1 wheel on the front pulley, but had the insurance that I could fit one if I totally fecked the ring up. Like I
said, a possible option, but not one to be taken on lightly....
Could you not do whatever it is caterham do? Or buy a flywheel off them/an owner/FleaBay?
You just need to get a flywheel of a 1.6 k series. That firts straight on I've just done it. Actually I might have a spare, I'll have a look.
The timing marks are mostly the same. I think it depends on year. Have a look on the BBS MG site for 16v k series midget and B's;
http://www2.mgcars.org.uk/cgi-bin/gen5?runprog=mgbbs&access=41729141105034&mode=tlist&subject=76
There's loads of info on there.
