Carbs, Ignition gubbings, seatbelts and more.
irvined - 6/2/08 at 04:18 PM
Hello,
Last december i finally got around to sorting out the bits i didnt fit. Heres the first batch, prices include postage in the UK.
-- TRS 6 point Seatbelts
They are bolt in, single seater, FIA approved in Red.
Both have 3" shoulder straps
One has 2" lap straps
One has 3" lap straps
The other straps are 1 and a bit"
Piccy: Bolt In
Piccy: FIA Approved
Piccy: One with 2" Lap belts
Piccy: Seatbelt with 3" lap belts
Which is this
-- Burton Power Crossflow dry sump rocker cover wotsit
Piccy: Top of crossflow rocker cover
Piccy: one side exit and one top exit
-- Working but dirty front calipers for cortina uprights. I replaced these because i thought they where dodgy, turned out to be the wheel bearing pushing the pads out, so a pair of perfectly working calipers:
Piccy: Cortina Calipers
-- Complete luminition setup for a crossflow, dizzy with static timing, luminition module and sensor etc, with coil and plugs.
http://www.irvined.co.uk/gallery/main.php?g2_view=core.DownloadItem&g2_itemId=112971&g2_serialNumber=1]Piccy: Luminition Setup
-- Some brake hoses, i bought these for doing between reservoir and masters but used rubber instead. About 30cm long.
These are the ones
Piccy: Brake Hose
-- DCOE 40 repair kit at least 2 of them
Piccy: DCOE Repair Kit
-- SVA wing mirrors - no scratches, dents or sharp edges these fell off to make way for my racetech ones.
Piccy: SVA Wing Mirrors
-- DCOE 40 carbs
I have a matched pair and also a single one, the matched pair started and ran, but i didnt have time or energy to tune them.
The single one was goign to go on my mini.
Piccy: Matched pair and a single DCOE 40
-- Prices
Seatbelts: 60 for the 2", 70 for the 3", or 120 for both.
Rocker: 55
Calipers: 30
Luminition 115
Brake hose 20 for both
DCOE Repair kit: 10 for both or free if you buy the carbs
Wing Mirrors: 25
DCOEs: 60 for the single, 130 for the pair.
[Edited on 6/2/08 by irvined]
coozer - 6/2/08 at 04:19 PM
Links don't work....
jammy_basturd - 6/2/08 at 04:24 PM
How much for the single 40?
Confused but excited. - 6/2/08 at 04:42 PM
You didn't list the prices.
irvined - 6/2/08 at 04:55 PM
Should all be there now with pictures.
MikeR - 6/2/08 at 06:37 PM
I'll take the wing mirrors.
