wrigglypig
| posted on 10/5/09 at 09:37 PM |
Its all got to go
For a host of reasons I have decided to sell up, I may come back to it in a couple of years, but can't hang on to it all.
If you are interested u2u me first come first served
all parts have been thoroughly cleaned and painted and appear as new seals, gaskets, bearings,grease etc as req. contact me and I'll give you
full details I am open to offers.
There is
fuly re built 1.8 cvh has new gasket ,pressure, tested,new head bolts , water pump cam belt tensioner , cam belt polished alloy distributor blanking
plate, powder coated rocker box shortened sump and pick up pipe, full new clutch, head rebuilt, pressure switches, custom inlet manifold gsxr 750
carbs with TPS alloy engine mounts vapour blasted, custom thermostat housing fitted to the rear of the head also fitted with type 9 5 speed box. Brand
new alternator, recon starter motor It can be seen running at http://www.youtube.com/watch?v=NcVMVosgZ5w
Both front hubs are mint in red lead primer with brand new vented discs
Factory recon front calipers painted in heatproof red with new pads etc
rear diff 3.9 again with new oil seals and gaskets
push in drive shafts totally dismantled and chemically cleaned re greased new metal covers and rubber boots
brake back plates refurbed with new wheel cylinders and brand new drums
Hynes roadster pedals powder coated in silver with grip tape fitted
7inch chrome headlights
recon Mk2 escort rack
Sierra column
header tank
steering extension
contact me if you are interested ther may be other bits I hav nt listed so shout up and Ill see if I have got it. I have the V5 it is SORNed and I
have the keys.
Kev
eccsmk
| posted on 10/5/09 at 09:53 PM |
bits for sale
how much for the pedals and the steering column??
thanking you
handyandy
| posted on 10/5/09 at 09:54 PM |
private message via Haynes forum
andy
RichardK
| posted on 10/5/09 at 09:58 PM |
Oh Kev thats a proper shame mate, hope to see you back soon fella although I'm sure Paul the Sixth wouldn't mind you getting your fix
helping him occasionally
Take care
Rich
Gallery updated 11/01/2011
wrigglypig
| posted on 10/5/09 at 10:09 PM |
Cheers Rich, Ill no doubt catch up with you when we get round to Pauls to pull his car to bitz
wrigglypig
| posted on 10/5/09 at 10:11 PM |
eccsmk you have a u2u
mookaloid
| posted on 10/5/09 at 10:30 PM |
U2U sent re rear brakes
RMarine
| posted on 10/5/09 at 10:39 PM |
u2u sent ...thx
cd.thomson
| posted on 10/5/09 at 10:42 PM |
what are the front calipers? sierra ones for the normal vented discs?
Craig
paul the 6th
| posted on 10/5/09 at 10:45 PM |
Eyup guys, yes I'm still here and lurking in the background. Been tied up with various other projects (inca BBQ for 25 people last wknd - talk
about hard work!) but I'm going to be back on track at the start of June... Just gotta get a week in Italy out of the way & I'll be
firing on all cylinders. Would you be interested in helping me & kev rich? Gonna hammer the donor over a wknd
Hope you're all well & I can vouch for kevs handy work with everything he's re-con'd & re-built, it's all immaculate
and works perfectly
GoDesign.me.uk - Self Adhesive Vinyl Artwork, Wide Format Printed Artwork and Customised Heat
Pressed Clothing...
http://picasaweb.google.com/haynesroadster - Roadster Photo Build Log
tilly819
| posted on 11/5/09 at 08:08 AM |
You have U2U chears
F20C Haynes roadster 440 BHP/Tonne www.youtube.com/handmadeextreme
Valtra
| posted on 11/5/09 at 04:15 PM |
Calipers ? are they Cortina ? if so how much ? will u2u
"If it looks like it works and it feels like it works, then it works"
