flak monkey
| posted on 26/4/10 at 09:01 PM |
Garage clearout - can take to stoneleigh
Righto - resigned myself to coming to Stoneleigh in the tintop now, which means loads of space to clear the garage out a bit!
All available for collection at Stoneleigh this weekend from Saturday afternoon onwards.
Sierra steering wheel - £5
Ford Coil pack suppressor capacitor ideal for MS - £5
350lb/in 1.9"ID springs in black - not in perfect condition as they were fitted to mine for 5000miles of all weather use - but they arent tatty
either. Were perfect with the pinto fitted. £20 pair.
HP fuel filter - £5
Low pressure fuel filter - £5
Odd offcuts of silicone hose all in black - come and find me and see what I have got. Mostly 32mm and 50mm. Also 50mm aluminium tube. Price depends on
what you want
2 lengths of fuel rail blank (18" each - each enough for a 4cyl easily) - £20/length
Standard Duratec sump - £15
New 220mm Clutch friction plate to suit almost all FWD fords. Small splines so not suitable for type 9. £5
CBR600 throttle bodies - no injectors but otherwise complete. These are the ones with sliders £40
Std duratec fuel rail - £10
Std CBR fuel rail - £10
Probably loads more stuff - will have another rummage tomorrow night.
[Edited on 26/4/10 by flak monkey]
Sera
http://www.motosera.com
big_wasa
| posted on 27/4/10 at 06:42 AM |
I will have a bit of fuel rail but I am not going to the show.
cheers warren
doddy
| posted on 27/4/10 at 07:07 AM |
Can I have the other fuel rail
u2u sent
cheers doddy
[Edited on 27/4/10 by doddy]
flak monkey
| posted on 27/4/10 at 07:33 AM |
Both bits of fuel rail gone.
Everything else available
Sera
eddie99
| posted on 27/4/10 at 11:13 AM |
Fuel rail can take in kit car. Can the people wanting the bigger bits PLEASE not tell David untill after Stoneleigh PLEASE.....
http://www.elitemotorsporteng.co.uk/
Twitter: @Elitemotoreng
Facebook: http://www.facebook.com/pages/Elite-Motorsport-Engineering/153409081394323
flak monkey
| posted on 27/4/10 at 11:31 AM |
Not going in the GTS anyway
I'll just be in the other yellow beast instead!
Sera
goaty
| posted on 27/4/10 at 09:12 PM |
can you let me know what bits of black hoses you have please dave?? poss interested in the 32mm ones as not got onto ordering mine in yet.
cheers
flak monkey
| posted on 28/4/10 at 06:54 AM |
Come and have a look if you are coming Theres lots of odd bits and pieces.
Some more to add to the list:
New ignition coil, ballast resistor type - I think I have the resistor somewhere as well. £10
2 off 90 deg 76mm/3" aluminium bends. Ideal for intercooler/turbo hoses. New, still wrapped. £20 pair
Idle air valve - 2 pin type from ford. £5
The coil over springs are 8.5" length IIRC.
Sera
flak monkey
| posted on 1/5/10 at 08:11 AM |
Last shout for anything specific?
Find the yellow Leon on the Locost area and come and say hi!
Sera
mid-buggy
| posted on 1/5/10 at 09:11 AM |
Will pop in for a nose about the hose and ss pipes.
Will be with 2 EBTs if you dont mind dogs?
