Garage clearout - Sierra, P100 and R1 bits.
I'm open to your best offers on all of the below. Feel free to u2u me or post below.
POSTAGE: I can post these items, but some are obviously a bit heavy and cumbersome. They will ship using 'ipostparcels' or any other
method you suggest.
COLLECTION: You're welcome to collect the items from Wray, Lancashire. The village is 15 minutes from J36 of the M6.
Sierra rear hubs:
![](/galpreviews/2Rear hubs.jpg) ![Rear hubs](/gallery/2Rear hubs.jpg) Rear hubs
Sierra hub carriers:
I got these shot blasted, without specifying that the bearings should be sealed off. So you'll need new bearings (probably a good idea anyway!).
I don't think the inside face is damaged.
![](/galpreviews/Rear hub carriers.jpg) ![Rear hub carriers](/gallery/Rear hub carriers.jpg) Rear hub carriers
Sierra front calipers
![](/galpreviews/2Front calipers.jpg) ![Sierra front calipers](/gallery/2Front calipers.jpg) Sierra front calipers
Steering racks
One of these is from a P100, the other from a Sierra - I don't think there is any difference between them. One doesn't have a pinion or
seal (see photo). One of the pinions in the next listing can be included.
![](/galpreviews/Racks 1.jpg) ![Racks](/gallery/Racks 1.jpg) Racks
![](/galpreviews/Racks 2.jpg) ![Racks 2](/gallery/Racks 2.jpg) Racks 2
Pinions for rack
![](/galpreviews/2Pinions.jpg) ![Pinions](/gallery/2Pinions.jpg) Pinions
Sierra steering column upper
![](/galpreviews/Column upper.jpg) ![Column upper](/gallery/Column upper.jpg) Column upper
Steering link
Shortened, will need lengthening.
![](/galpreviews/Steering link.jpg) ![Steering link](/gallery/Steering link.jpg) Steering link
Sierra ignition assembly
Key, barrel, switch and horn contacts. As seen in the photo, part of the casting has broken. You might want to repair it, I haven't bothered
yet!
![](/galpreviews/Sierra ignition barrel and casting.jpg) ![Sierra ignition](/gallery/Sierra ignition barrel and casting.jpg) Sierra ignition
P100 steering column
The wheel end of the column needs a nut, not a bolt like a standard Sierra column.
![](/galpreviews/P100 column.jpg) ![P100 column](/gallery/P100 column.jpg) P100 column
![](/galpreviews/P100 column 3.jpg) ![P100 column 3](/gallery/P100 column 3.jpg) P100 column 3
Sierra steering wheel
With horn centre. I don't know if the horn switch is working.
![](/galpreviews/18Wheel.jpg) ![Wheel 1](/gallery/18Wheel.jpg) Wheel 1
![](/galpreviews/5Wheel 2.jpg) ![Wheel 2](/gallery/5Wheel 2.jpg) Wheel 2
Upper column surround
The adjustable part has been cut off.
![](/galpreviews/Upper column outer.jpg) ![Upper column outer](/gallery/Upper column outer.jpg) Upper column outer
Unknown hub (P100?)
![](/galpreviews/Unknown rear hub 2.jpg) ![Unknown rear hub 2](/gallery/Unknown rear hub 2.jpg) Unknown rear hub 2
![](/galpreviews/Unknown rear hub.jpg) ![Unknown rear hub](/gallery/Unknown rear hub.jpg) Unknown rear hub
R1 (4XV/5JJ) airbox
Should fit 4XV and 5JJ.
![](/galpreviews/Airbox back.jpg) ![airbox back](/gallery/Airbox back.jpg) airbox back
![](/galpreviews/airbox front.jpg) ![Descriptionairbox front](/gallery/airbox front.jpg) Descriptionairbox front
