MK Indy R race car huge spec
I have for sale my 2010 MK Indy R for sale, the car was originally built as a bike engine and in 2019 was completely stripped, chassis modifications
made to convert to a car engine (ford Zetec).
Modifications made to the chassis included wider transmission tunnel the swan neck being removed from the roll cage down tube, the chassis was then
powder coated in black.
The car was built to race in the 750mc Sports Specials class B, however it is able to partake in a number of different championships if required, can
be used as a very good track day car or even with some modifications converted to a road spec car.
In describing the car please make no doubt this car has been built as and used as a race car, so there are some scuffs and scrapes however this has
been built to a high build spec not often found-
Engine and transmission and running gear-
Engine-
Recently refreshed 2.0 Zetec, fast road cams, Jenvey 40mm Individual Throttle bodies, ECU is a Megasquirt 3 and the car is mapped by Dale at Bailey
Performance. The car is running 190BHP
Turbosport lightweight flywheel
Raceline RWD water rail
Raceline wet sump
50mm alloy radiator
Oil cooler
Type 9 gearbox, close ratio race box from Tracsport roller bearing heavy duty gear kit gear ratios are-
1st 2.2
2nd 1.54
3rd 1.21
4th 1.0
5th 0.87
Rear Diff- Sierra 7” push in shafts LSD Quaife ATB with 3:9 CWP
Fuel system- PTFE Braided Fuel lines front to back, low pressure fuel pump feeds a 1.5 litre swirl pot then a Bosch 044 from swirl pot to the ITB’s
Brake system
Independent front and rear master cylinders brakes braided hoses from the master cylinders to calipers.
Front-Wilwood Midi-lite 4 pot brakes with grooved discs
Rear-Wilwood Power Lite 4 pot callipers
Front and rear Protech single adjuster shocks and springs
Others/Extras
Drivers side has a 6 point harness fitted
Passenger side 4 point harness fitted
1 litre catch can fitted
Quick rack 2.4 fitted
OMP 4.5litre fire extinguisher fitted with 2x pull cords
Wheels 4x 15” Team dynamics pro race 1.2 with Nankank AR1’s
Spare full set of body work- nose cone, scuttle, rear tub, rear arches
Spare 1800 Zetec block and head
The above Spec is £8,995 ono
The car can be sold with a lower spec than above if needed so this would be with following changes-
Gearbox- standard type 9 gear box
Diff- fitted with a Sierra standard 7” Diff
Brakes standard Sierra front and real callipers would be fitted
Price would be £5,995
I have tried to load pics but not working eBay as is below please ask any questions
https://www.ebay.co.uk/itm/MK-Indy-R-Race-Car-locust-tiger-Westfield-Caterham-/174984711181?mkcid=16&mkevt=1&_trksid=p2349624.m46890.l49286&am
p;mkrid=710-127635-2958-0
